I2C function routines in C for interfacing a micro
arup
Member level 2
I2C programming
hello,
I am new to microcontroller based applications.right now i am using a micro(ST7FLITE09) which is not having a I2C port.i need to communicate with 24c08.How can i do that...I need to write a software emulated code for interfacing the micro with eeprom.i know the steps..start+slave addr+r/w+ack+location addr+ack+data+........+stop
Can anyone help me giving some code written in C...What way i can write all those routine. what way and how can i make low & high those SDA & SCL lines...
pls help.
thanks,
arup
mrcube_ns
Advanced Member level 1
Europe
Re: I2C programming
Simply, put pull up resistor 4k7 on two (output) pins of mcu and thats it.
I will upload routines when I came home from work.
Tip: try to find routines on board, you're not first one which need those routines, or try with google.
Mr.Cube
Iain
Re: I2C programming
The attached zip includes software implemented I2C routines for the PIC and may be a useful starting point.
To view the schematic you will need a demo version (or better) of Proteus.
Iain.
sacrpio
Member level 3
Re: I2C programming
If your controller is not having I2C support. You can use port pin for this.
If you are interested in assembly written code then search on phillips semiconductor url. It is given there.
Any other supprt related to I2C write me???
arup
Member level 2
Re: I2C programming
hello,
can anyone pls give I2C coding written in C.
Thanks,
arup
amazonite
Member level 3
Re: I2C programming
I have write i2c function code in C. You can reference the code in attachment.
Bluechem
Member level 4
I2C programming
hello arup, there are free I2C routines both in C and assembly available in internet ( I believe you can find a good one in philips site). I suggest you first go to philips site and read I2C manual and understand I2C protocol thoroughly, because if you are planning to use a pre-written routine without understanding I2c there s a great chance that you will end up with spending much more time for troubleshooting
