I2C example pic18f24k50 with mikroC
cllunlu
Member level 4
Hi Everyone,
I wanna i2c communication between pic18f24k50 and at24c64. I have looked at i2c example in mikroC library manager. But I couldnt understand it. Especially read and write functions. Anyone Show some simple example.
A0,A1 and A2 pin is grounded.
Thank you...
Hello,
So as per the details you provided I assume that you are using MikroC compiler
So I will tell you the general idea
1. As you have mentioned the pins are grounded so the bits(A0, A1 andA2) will be ZERO in the 7 bit address of at24c64. (please refer datasheet)
2. Now the you start like this
HTML:
// FOR WRITING DATA to Slave
1.>Start I2C Communication
2.> Send I2C 7 bit address along with LSB (0th bit) as ZERO [IF you want to write Something LSB has to be Zero]
3.> Write the Data
4.> Stop I2C Communication
HTML:
// FOR READING
2.> Send I2C 7 bit address along with LSB (0th bit) as Logic - ONE [IF you want to READ Something LSB has to be ONE]
3.> Restart I2C Communication OR Stop and Start I2C communication
4.> Read Data
5.> Stop I2C Communication
Try to implement this using the library functions(I2C) provided by Mikro C and let me know if you face any difficulty
mikroC PRO PIC comes with an example of I2C eeprom. Use it. It works for me.
Edit:
I2C1_Init(100000);         // initialize I2C communication
I2C1_Start();              // issue I2C start signal
I2C1_Wr(0xA2);             // send byte via I2C  (device address + W)
I2C1_Wr(2);                // send byte (address of EEPROM location)
I2C1_Wr(0xAA);             // send data (data to be written)
I2C1_Stop();               // issue I2C stop signal
Delay_100ms();
I2C1_Wr(2);                // send byte (data address)
I2C1_Repeated_Start();     // issue I2C signal repeated start
I2C1_Wr(0xA3);             // send byte (device address + R)
LATB = I2C1_Rd(0u);        // Read the data (NO acknowledge)
I2C1_Init(100000);
//I2C1 communication is initialized at 100 kbps baudrate
I2C1_Start();
//I2C1 communication is started, only master controls the I2C clock
I2C1_Wr(0xA2);
//The address byte for AT24LC64 is formed like this
bits 7 to bits 4 will be 1010. This is the 4bit control code for read or write.
bits 3 to 1 for the actual address set on the eeprom chip. Here it is 001
bit 0 is Read/Write bit.
Here we are writing to eeprom so bit 0 is 0 and so the address byte becomes
1010 001 0 = 10100010 = 0xA2
I2C1_Wr(2);
Next he is sending address of eeprom location (2).
So the data that will be sent next will be written at eeprom address 0x02
I2C1_Wr(0xAA);
Now data 0xAA is written at address 0x02 of eeprom
I2C1_Stop();
I2C communication is stopped.
Now reading data from eeprom and displaying the read byte on PORTB.
These three lines are already explained
Now a repeated start signal is issued
Now read address has to be sent so in the address byte the bit 0 will be 1
so the address byte will be
1010 001 1 = 10100011 = 0xA3
Read address is sent.
I2C1_Wr(0xA3);
eeprom sends data at address 0x02.
master reads the data and does a not ack.
LATB = I2C1_Rd(0u);
I2C1_Stop();
I wanna use at24c64 eeprom. The address is 0x0000 to 0x1FF. When I send to the address to eeprom, How do I write. For example first hi part, after that low part?
Yes, you have to send Address high byte first and then Address Low Byte and then data to be written to eeprom.
