Conversation opened. 1 unread message.
Skip to content
Using Gmail with screen readers
More
1 of 21,952
i2c pic16
Inbox
x
sanket meher
Attachments3:47 PM (4 minutes ago)
to me
PFA
2 Attachments
Click here to Reply or Forward
2.73 GB (18%) of 15 GB used
Manage
Terms - Privacy
Last account activity: 0 minutes ago
Details
/* I2C library*/
#include <xc.h>
#include "i2c.h"
// The flag to indicate whether an I2C error has occured.
unsigned char b_i2c_error_flag = 0;
// Function Purpose: Configure I2C module
void InitI2C(void)
SDA_DIR = 1; // Make SDA and
SCK_DIR = 1; // SCK pins input
SSP1ADD = 0x4F;//((_XTAL_FREQ/4000)/I2C_SPEED) - 1;
SSP1STAT = 0x80; // Slew Rate control is disabled
SSP1CON1 = 0x28; // Select and enable I2C in master mode
unsigned char b_i2c_check_error_flag(void)
return b_i2c_error_flag;
// Function Purpose: I2C_Start sends start bit sequence
void I2C_Start(void)
SSP1CON2bits.SEN = 1; // Send start bit
while(SSP1CON2bits.SEN == 1); // Wait for it to complete
// Function Purpose: I2C_ReStart sends start bit sequence
void I2C_ReStart(void)
SSP1CON2bits.RSEN = 1; // Send start bit
while(SSP1CON2bits.RSEN == 1); // Wait for it to complete
//Function : I2C_Stop sends stop bit sequence
void I2C_Stop(void)
SSP1CON2bits.PEN = 1; // Send start bit
while(SSP1CON2bits.PEN == 1);
//Function : I2C_Send_ACK sends ACK bit sequence
void I2C_Send_ACK(void)
SSP1CON2bits.ACKDT = 0; // 0 means ACK
SSP1CON2bits.ACKEN = 1; // Send ACKDT value
while(SSP1CON2bits.ACKEN == 1); // Wait for it to complete
//Function : I2C_Send_NACK sends NACK bit sequence
void I2C_Send_NACK(void)
SSP1CON2bits.ACKDT = 1; // 0 means ACK
// Function Purpose: I2C_Write_Byte transfers one byte
void I2C_Write_Byte(unsigned char Byte)
// Clear the error flag before we start a new I2C operation.
SSP1BUF = Byte; // Send Byte value
while (SSP1STATbits.R_W == 1);// Wait for slave to acknowledge.
// If slave does not acknowledge...
if (SSP1CON2bits.ACKSTAT == 1) {
// Send stop bit.
while (SSP1CON2bits.PEN == 1);
// Set the error flag and exit.
b_i2c_error_flag = 1;
return;
// Function Purpose: I2C_Read_Byte reads one byte
unsigned char I2C_Read_Byte(void )
SSP1CON2bits.RCEN=1; // Enable to receive data
// Wait until the data is received.
unsigned long count = 10000L;
while (SSP1STATbits.BF == 0) {
// If timeout...
if (--count == 0) {
// Send stop bit.
return 0;
return SSP1BUF; // Return received byte
i2c.c
Displaying i2c.c.
