I2C communication code for PIC16F877A in Mikro C
ammmmu
Newbie level 3
Dear friends,
I need to PIC 16F877A in I2C mikro C coding please help me my friends.....
milem
Newbie level 6
coding for i2c
Here is code for I2C communication what i have!
Is for 8051 microcontrollers, but ca be easily adopt to any micro.
Is written in Keil C!
If you want in assembler you can find it on net!
besthabit
Junior Member level 3
Islamabad
i2c keil c
24XX512.h
#include "i2c.h" /* Need i2c bus */
#define EEPROMS_ID 0xA0 /* Microchip 24xx512 */
unsigned char EEPROM_get(unsigned int addr)
unsigned char dat;
I2C_start(); /* Start i2c bus */
I2C_write(EEPROMS_ID); /* Connect to EEPROM */
I2C_write(addr&0xF0); /* Request RAM address (Hight byte) */
I2C_write(addr&0x0F); /* Request RAM address (Low byte) */
I2C_write(EEPROMS_ID+1);/* Connect to EEPROM for Read */
dat = I2C_read(); /* Receive data */
I2C_noack();
I2C_stop(); /* Stop i2c bus */
return dat;
void EEPROM_set(unsigned int addr, unsigned char val)
I2C_start();
I2C_write(val); /* Write sec on RAM specified address */
Added after 46 seconds:
i2c.h
#define SDA P2_2 /* Set P2.7 = SDA */
#define SCL P2_3 /* Set P2.6 = SCL */
#define I2C_DELAY 0x0F /* For delay i2c bus */
void I2C_delay(void)
unsigned char i;
for(i=0; i<I2C_DELAY; i++);
void I2C_clock(void)
I2C_delay();
SCL = 1; /* Start clock */
I2C_delay();
SCL = 0; /* Clear SCL */
void I2C_start(void)
if(SCL)
SDA = 1; /* Set SDA */
SCL = 1; /* Set SCL */
I2C_delay();
SDA = 0; /* Clear SDA */
I2C_delay();
void I2C_stop(void)
if(SCL)
I2C_delay();
I2C_delay();
bit I2C_write(unsigned char dat)
bit data_bit;
unsigned char i;
for(i=0;i<8;i++) /* For loop 8 time(send data 1 byte) */
data_bit = dat & 0x80; /* Filter MSB bit keep to data_bit */
SDA = data_bit; /* Send data_bit to SDA */
I2C_clock(); /* Call for send data to i2c bus */
dat = dat<<1;
I2C_delay();
I2C_delay();
data_bit = SDA; /* Check acknowledge */
I2C_delay();
return data_bit; /* If send_bit = 0 i2c is valid */
unsigned char I2C_read(void)
bit rd_bit;
unsigned char i, dat;
dat = 0x00;
for(i=0;i<8;i++) /* For loop read data 1 byte */
I2C_delay();
I2C_delay();
rd_bit = SDA; /* Keep for check acknowledge */
dat = dat<<1;
dat = dat | rd_bit; /* Keep bit data in dat */
return dat;
void I2C_ack()
I2C_delay();
void I2C_noack()
I2C_delay();
Added after 1 minutes:
main
#include <AT89X51.H>
#include <24xx512.h>
unsigned int del,i,x,temp;
char getCharacter (void)
char chr; // variable to hold the new character
while (RI != 1) {;}
chr = SBUF;
RI = 0;
return(chr);
void send (char a)
SBUF = a;
while (TI != 1);
TI=0;
void main (void){
char chr;
int i=0,j=0,count=0,inc=47;//inc=47
int index=0;
P1=0X00;
P2=0X00;
SCON = 0x50; // mode 1, 8-bit uart, enable receiver
TMOD = 0x20; // timer 1, mode 2, 8-bit reload
TH1 = 0XE6; // 1200
TL1 = 0XE6;
TR1 = 1;
TI = 0;
SBUF =0;
while(1){
your code
}//end of while
}//end of main
manish12
Advanced Member level 3
set byte in micro c
i am getting an error for both lib,
reiniheini
Member level 1
i2c code in c
which compiler you're going to use???
depending on that you have to verify if the base libraries are available...
besthabit
Islamabad
i2c+sbuf
i m using microvission keil & proteous & this code is perfectly workin fine
it only gives one warning msg bcaz of ack function bcaz m not using any ack during read & write in my code
