I want to know how to design a current checker
dwara
Newbie level 2
Hello! I want to know how to design a circuit for checking curent. I have a relay coil it operates whenever supply is provided but the thing is i want to operate the relay only when the current is 10-20A below 10A or above 20A the relay should not work. To a minimum extend It should not operate below 10A. Thanks in advance
What I gather from your post is that you want to design a sort of undercurrent and overcurrent protection.
You need a means of reading the current. You can do this using shunt resistor, current transformer or hall-effect sensor. Your method will depend on AC/DC and cost factor.
Then you need to compare the current to 2 references - one for 10A and one for 20A. And then take necessary action when current < 10A or > 20A. This can be done using comparators or microcontroller. If you don't use or haven't used microcontrollers, designing the circuit with comparators will be easier than using microcontroller.
Hope this helps.
Tahmid.
Reactions: dwara
    dwara
Hope this helps.
Tahmid.
Thank you so much. :);-):idea:
