I want to build a small circuit board? But I require some help?
xCROSSAx
Newbie level 2
Newbie level 2
My plan is modifying a Xbox 360 console(phat), to add a extra SATA port by desoldering the internal Hdd connector, i have the pin out of voltages but i would like to solder headers from the pin out on the motherboard (the right side as that is the pin out for SATA data) and solder a header socket to a small circuit board and then solder a SATA data port on the circuit board, but the thing that is bothering me i whether or not i will need to solder any resistors on the circuit board i will then find voltage sources to wire a SATA power connector to power a hard drive.
