I/O Buffer (IOB) vs. Global Clock I/O Buffer (GCLKIOB)
farrokhiyan
Junior Member level 3
clock_dedicated_route
Hi all,
Would you please tell me what is the difference between standard I/O Buffer and Global Clock I/O buffer?
how can i explicitly instantiate an I/O Buffer component for each top-level I/O signal in xilinx ISE?
tnx.
TekUT
Full Member level 6
Italy
xil_place_allow_local_bufg_routing
From what I can remember global clock buffer are dedicated to route signal over specialized track inside the FPGA in order to minimize the skew from every block inside the device, is a sort of low timing path connected to every FF clock input that is inside the logic block.
Bye
Pow
    farrokhiyan
farrokhiyan
gclkiob
How can I instantiate a Clk signal to a standard I/O buffer (not global buffers)?
what is CLOCK_DEDICATED_ROUTE ?
pwq1999
Member level 2
gclkiob xilinx
just take a look at the language template, there are lots of example available.CLOCK_DEDICATED_ROUTE means that path is dedicated for clock,the path with least skew and is suitable to route clock.
ring0
Member level 3
Moscow, Russia
In order to use a clock signal with a standard I/O pin in Xilinx FPGAs, an environment variable XIL_PLACE_ALLOW_LOCAL_BUFG_ROUTING must be set.
