Dear all,
I need to send the data to PC from my MCU via USATR. I did it using MAX232 Protocol
So my request is the data received to PC,I need to store in the Database or Spreadsheet
currently the data received to Hyper terminal
Is there any software better than Hyper terminal which easy to capture data and store in the Database
My MCU is 16f877a
Please help
Thanks in advance
Dear All
Thanks for reply
As I know in Asynchronous transmission mode the clock rates not sync both Tx and Rx side which is independent clocks rate.
Let suppose, we need to communicate between two devices with different clock rates or maximum clock rate
Please advice me how can we implements such situation using MCU like pic 16f877a
please advice
Thanks in advance
You can also look at https://www.docklight.de/
For more specific data types, i guess you will need to write your own program on PC.
I suggest to use Visual Studio Express.
The Serial Port port useage is quite simple.
If two MCUs are to communicate with each other via UART, or an MCU with PC via RS232, baudrates must be synchronized.
In your situation it seems that there is no problem, set the same baudrate on both devices. Except if it is something else that you need that I did not got it clearly.
if you send your data (ascii format) to a "hyper terminal" witch has the capacity of logging all data in a file,
you can use Comma Separated Value CSV (excel) format .. and then export as Database with excel or directly use excel as simple database.
An other way is to use DBF format (old but simple to use) to build a file data.
