speech vocoders
hi all,
I need speech vocoders(G.722) for the VoIP project I am working on. It should fit into a low cost DSP from Analog Devices or TI that will receive data from a 16 bit A/D - D/A and store it in a flash using some sort of audio compression, (The audio is speech only) then each sample needs to be tagged for later retrieval, meaning it is not A FIFO, we should be able to retrieve any and all audio files stored in flash whenever and also be able to store a small amount of data.
Any suggestion?
