lorenzo_99
Newbie level 3
I found this schematic which I require to build for MSU programming.
Although I am quite interested in electronics as a hobby, I am by no means an expert on the subject, and this is by far the most complex circuit I have attempted to build.
Transferring the schematic to trackboard I found to be particularly complex, and I just wanted to clarify whether or not the trackboard layout shown below for the schematic (also below) would work.
There are also a few other questions I have regarding this subject, firstly regarding the schematic, I have circled two areas in red which I am not sure about their meaning, and how they would be duplicated on the trackboard design if needs be.
Secondly, I was wondering about the power source for this circuit, and whether or not it could somehow be derived from the serial port, and if so which pins to draw from.
Finally, the programming of the MSU chip would require direct soldering onto the pins of the chip itself, which I have heard is possible and is done all the time, but I was wondering if this would require a lower wattage soldering iron (say 15W) along with reduced contact time, or would these precautions still leave a risk of burning the chip.
the schematic:
the trackboard layout:
Thanks in advance for any help on this.
the schematic:
