Plecto
Full Member level 5
I would like to fill some holes in my op-amp knowledge. I currently have some static noise and slight humming in my recent amplifier design and I'm thinking that the source might be the PSRR of the op-amp used, but how do I calculate it? I made this simple circuit that has +/-25V rails with 1V of humming present:
First off, the input offset voltage is a voltage that is present on the input of the amplifier, right? This voltage will vary slightly with supply voltage so that any ripple present on the supply will appear on the inputs of the op-amp, is this correct? If the input bias voltage is equally present at both the inverting and non-inverting input of the op-amp won't they then always cancel each other out regardless of how much ripple that is present on the supply? Also, the input bias voltage has to depend on the input resistor as well, doesn't it? I've chosen a 100kOhm input resistor in this schematic, but as this value drops, so does the input bias voltage, doesn't it? I'm also wondering if perhaps the input bias current also varies with supply voltage? Thing is that the humming I have in my recently made real life amplifier will vary greatly with the input resistor value chosen, almost going completely away if I short the non-inverting input to ground.
The op-amp in the schematic attached is a OPA551 which has a 'input offset voltage vs. supply voltage' of 10uV/V. If I have 1V of ripple and a gain of 2.5, would that lead to an output voltage of 25uV? One last question about input bias current, how can current flow in or out of it's inputs when it's got fet inputs?
