lylnk
Member level 1
- Joined
- Sep 12, 2005
- Messages
- 33
- Helped
- 4
- Reputation
- 8
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- China Beijing
- Activity points
- 1,483
I have designed a high voltage detection circuir. The input high voltage can be 0v~16v. I use two poly resistors to divide input high voltage to 0~3v. The total resistance of resistors is about 200kohm. The circuit is fabricated upon 3.3v process.
There is a question on the ESD protection of high voltage input pin.
There is no active device can withstand 16v. I have not find any device, whose bread down voltage exceed 12V, except NW/PSUB diode. The typical break down voltage of NW diode is 14V. I think the minimum break voltage will be less than 12V.
The field oxide under poly is about 350nm. It is deposited perhaps. I think the break down voltage of the oxide is about 200V.
How can i survive under 2kv human body ESD model? I need help.
Will the ESD damage the field oxide?
