I need help choosing proper filter for PLL design
mostafa0020
PLL Filter Design"?
Hi ALL,
I use "4046 Chip " as a PLL with a reference frequency of 50 Hz " Power Frequency" with a divider in feedback N=60 "two 4017 Chips" and using Phase Comparator 2 to obtain zero degree phase shift between input and output when in lock, the VCO is a wave generation circuit consisting of "ICL8038 Chip" linear triangular VCO,The problem is closing the loop with a suitable filter.
Please, Advise me about selecting the proper filter " wheather active or passive, 1st or 2nd order,.." elements,how can I calculate this filter elements????
Re: PLL Filter Design"?
For this application you do not need an active filter.
Even a first order filter will be adequate, and personally that is what I would use.
For details on how to design it, check out page 6 of this datasheet: https://www.onsemi.com/pub/Collateral/MC14046B-D.PDF
The reference clock is very low and nothing concern voice and audio application, just simple RC filter is enough.
