I need help about Assembler
user0123
I'm adjusting RTC with keypad. Show the press key on the LCD.
Example: I compare if the press key is $5 - if it's pressed I write it to variable and show on the LCD. After that I compare if another key is pressed, write its value in second variable and show it on the next position on the LCD.
I don't know how to do the following thing: I have the value $5 in one variable and $9 in other variable. I have to write in the RTC $59. How to do this?
After the call of "keypad_wytec": if a key is down, the carry bit =1 and the accumulator B holds the key number, if no key is down the carry bit =0
adjustment:
jsr lcd_ini_blink
ldx #str3
ldab #40
jsr lcd_line1
adj21: jsr keypad_wytec
stab Oldkey
ldaa Oldkey
cmpa #$05
bne adj21
staa value1
adda #$30
jsr adj1
adj22: jsr keypad_wytec
stab Oldkey
ldaa Oldkey
cmpa #$09
bne adj22
staa value2
adda #$30
jsr adj2
rts
adj1:
staa str4
jsr show_strings1
rts
adj2:
staa str4+1
jsr show_strings1
rts
str4 fcc ' '
show_strings1:
pshx
ldx #str4
ldab #2
jsr lcd_line2
pulx
rts
This code is only for test if everything is working.
P.S. The microcontroller is MC68HC11
Mathematically you have to do
RTC = value1*16 + value2
Programmatically you can do
value1 = value1 <SHIFT_LEFT> 4
value1 = value1 <BITWISE_OR> value2
RTC = value1
Just replace the ITALICS above with the mnemonics that best suit your needs (ASL/LSL).
Arthur
No.
I don't think you are right.
Value1 = 5
Value2 = 9
I must write 59, but not 5+9=14
P.S. I don't have BITWISE_OR operation in the command set.
Well, that’s not what I said, just read my post again!
But let me explain this again with your words:
So you wanted to get $59 (or 89 in hexadecimal representation, which the ‘$’ sign stands for) having a value1 = $5 and a value2 = $9, right?
In my post above I wrote:
value1*16 + value2, which give 5*16 + 2 = 89, or $59.
For the sake of optimization, the same result you get by shifting $5 left 4 bit positions (gives 80 = $50), then OR-ing (ORAA/ORAB, same as adding in this case, but probably faster than ADDA) the result with $9 (giving 80+9=89, or $59).
Are we in tune now?
Arthur
    user0123
Thank you very much.
It's working.
This is the last thing which I had to done, but it's now complete and I can finish my project.
Again THANK YOU VERY MUCH.
