i need c source on pcf8574 of lcd.
zk543g
korea
pcf8574
hello.
i need c source.
pcf8574 pic
PCF8574 is an I2c port expander. You need the I2c driver for whatever system (CPU or OS) you are using.
There are lot of sample I2c C codes from IC makers (P*hli*ps, A*tm*el etc).
Hope it helps
i2c pcf8574 c programm lcd
hello. huahua.
i need lcd_i2c_write() function c source.
help me.
pcf8574 c source
It's in German, but you can altavista's translator
pcf8574 lcd
Here is the i2c_write function using bit bang.
void i2c_write (unsigned char output_data)
unsigned char index;
for(index = 0; index < 8; index++) // Send 8 bits to the I2C Bus
// Output the data bit to the I2C Bus
SDATA = ((output_data & 0x80) ? 1 : 0);
output_data <<= 1; // Shift the byte by one bit
SCLK = 1; // Clock the data into the I2C Bus
SCLK = 0;
index = SDATA; // Put data pin into read mode
SCLK = 1; // Clock the ACK from the I2C Bus
SCLK = 0;
pcf8574 i2c programming
hi,What is altavista's translator and how can get it?
pcf8574 basic example code
greencateye,
Altavista translation is page where you can translate text or web pages from on language to others. Go there and check yourself, you will find out.
regards
meax98
c code for pcf8574
Well it does not become in LCD output of the pcf8574. The lcd_i2c_cmd, the possibility of repairing in the lcd_i2c_chr it is? Cumulation assist.
pcf8574 interrupt example
Maybee this can help you! I'm using PIC + PCF8574 + LCD + PicBasic Pro and it is working. All info I find here:
Interfacing with a Philips PCF8574 8-Bit I/O Expander
http://www.phanderson.com/PIC/16C84/8574_1.html
LCD-Module am I²C-Bus
I2C - Funktionsbeschreibung der Lib's
ePanorama.net I2C
And I send you two examples in basic for 80c535 MCU for interfacing PCF8574 and 4-bit LCD. I wrote my PIC program porting this source.
regards
meax98
