I need any circuit for "sensor of movement"
josquill
Junior Member level 2
Hi
tnks.
:roll:
1. Movement (shock). You can use a piezo buzzer as a sensor. You can even use a mecahnical relay to sense some amount of shock. Or you could use an accelerometer if you want to spend money.
2. Movement (displacement). LVDT, linear encoders, reisitance sliders.
RF doppler sensor can do it
May I know which brand and model of RF doppler sensor is cheapest?
The problem of such sensor are that they are mostly fabricated for OEM's.
So there is nearly no chance to get a single one.
One possibility is to get a door-opener and to reuse it's doppler-module
(most a gunn-source with demodulator). Most of them are working on
the K-Band (24GHz), but there also exist (bigger ones) at X-Band (10GHz)
Perhaps you will find on the internet something if you search with terms
like 'gunn source', 'doppler module' or 'movement sensor'
Greets
search for an old microwave anti-theves device. It works in the 10ghz band tipycally.
proton
