I NEED A SIMPLE 4mA-20mA DIGITALLY VARIABLE CURRENT SOURCE
roykyn
Full Member level 5
variable current source
it should be digitally controlled...may be 12 bit is enough
4ma to 20ma why is using
Here is an example of 4-20mA tester based on PICAXE microcontroller:
It is 10-bit conversion and the code can be easily modified not to take control form a potentiometer but from the serial port ..
Regards,
IanP
0 to 20ma variable current source
AD421
what is the 4ma-20ma
sorry cant use the picaxe....the methoud u suggest should be the cheapest....
