I need a low voltage, voltage adder circuit????????
SUNBELT
Member level 2
I need a low voltage, voltage adder in cmos technology, specially the one that can generate (v1+v2)÷2.
should I use a low voltage opamp? is there any other way
on1aag
Full Member level 3
Hi SUNBELT,
Although it's a very sophisticated circuit you should consider using it.
on1aag.
    V
SUNBELT
Member level 2
We all know about voltage dividing principle, I need a CMOS circuit, specially a low voltage one.
tlihu
Full Member level 6
The voltage dividor is the most common one. Why u want something else? Can you show me the specs or applications?
homer-s
Newbie level 1
On that low voltage circuit, how would you lay out a multiple input voltage averaging circuit (high impedance, high precision with say, 8 inputs)?. Thanks.
