i need a code for stop watch timer
verilog learner
Newbie level 1
Hello,
I am verilog learner, i need a code for stop watch timer. the one i have written shows few error. and also i am not getting how to interface with the lcd. i am using spartan 3 xc3s400 kit....pls help me....
U can get the verilog code for stopwatch written in verilog language quite easily. If you are beginner, forget about the FPGA board at this moment. Focus on running the code successfully. After you successfully checked the code of stop watch timer, move on towards the LCD. Learn about the LCD initialization. To display something on LCD, we firstt have to initialize LCD. There is a whole process of it. After the initialization, then move towards the FPGA board. There is a whole new science of how to run the code on FPGA board. But first, simulate your code. and after that, contact me. I will tell you how to run the code on FPGA board
module Stop_watch(
input [17:0]SW,
input [3:0] KEY,
input CLOCK_50,
output [17:0] LEDR,
output [7:0] LEDG,
output [6:0] HEX0,
output [6:0] HEX1,
output [6:0] HEX2,
output [6:0] HEX3,
output [6:0] HEX4,
output [6:0] HEX5,
output [6:0] HEX6,
output [6:0] HEX7
//assign HEX0=7'b111_1111; //off 7-segment Display
assign HEX1=7'b111_1111;
//assign HEX2=7'b111_1111;
//assign HEX3=7'b111_1111;
//assign HEX4=7'b111_1111;
//assign HEX5=7'b111_1111;
assign HEX6=7'b111_1111;
assign HEX7=7'b111_1111;
assign LEDR[17:0]=SW[17:0]; //SW status =>LEDR
wire [3:0] digit1,digit2,digit3,digit4,digit5;
wire clk_1hz;
/*module stopwatch(
input clock, //clock_50MHz
input reset,
input start, //Enable
output reg [3:0] d5,d4,d3,d2,d1
stopwatch u0(CLOCK_50,KEY[0],SW[17],digit5,digit4,digit3,digit2,digit1);
hex_7seg u3(digit1,HEX0);
hex_7seg u4(digit2,HEX2);
hex_7seg u5(digit3,HEX3);
hex_7seg u6(digit4,HEX4);
hex_7seg u7(digit5,HEX5);
endmodule
module stopwatch(
input reset,
reg [22:0] ticker; //23 bits needed to count up to 5M bits
wire click;
//the mod 5M clock to generate a tick ever 0.1 second
always @ (posedge clock or negedge reset)
begin
if(!reset) //DE2-70 KEY[0]=normal Hi , so pressed down is Low
ticker <= 0;
else if(ticker == 5_000_000) //if it reaches the desired max value reset it
ticker <= 0;
else if(start) //only start if the input is set high
ticker <= ticker + 1;
end
assign click = ((ticker == 5_000_000)?1'b1:1'b0); //click to be assigned high every 0.1 second
begin
if (!reset)
begin
d1 <= 0;
d2 <= 0;
d3 <= 0;
d4 <= 0;
d5 <= 0;
end
else if (click) //increment at every click (0.1Sec)
begin
if(d1 == 9) //xxx9 - the 0.1 second digit
begin //if_1
d1 <= 0;
if (d2 == 9) //xx99
begin // if_2
d2 <= 0;
if (d3 == 5) //x599 - the two digit seconds digits
begin //if_3
d3 <= 0;
if(d4 == 9) //9599 - The minute digit
begin //if_4
d4 <= 0;
if (d5==5) //59599--- The 10's minute digit
d5 <= 0;
else
d5=d5+1;
end // end if-4
else
d4 <= d4 + 1;
end
else //else_3
d3 <= d3 + 1;
end
else //else_2
d2 <= d2 + 1;
end
else //else_1
d1 <= d1 + 1;
end
end
endmodule
module hex_7seg(hex_digit,seg);
input [3:0] hex_digit;
output [6:0] seg;
reg [6:0] seg;
// seg = {g,f,e,d,c,b,a};
// 0 is on and 1 is off
always @ (hex_digit)
case (hex_digit)
4'h0: seg = 7'b1000000;
4'h1: seg = 7'b1111001; // ---a----
4'h2: seg = 7'b0100100; // | |
4'h3: seg = 7'b0110000; // f b
4'h4: seg = 7'b0011001; // | |
4'h5: seg = 7'b0010010; // ---g----
4'h6: seg = 7'b0000010; // | |
4'h7: seg = 7'b1111000; // e c
4'h8: seg = 7'b0000000; // | |
4'h9: seg = 7'b0011000; // ---d----
4'ha: seg = 7'b0001000;
4'hb: seg = 7'b0000011;
4'hc: seg = 7'b1000110;
4'hd: seg = 7'b0100001;
4'he: seg = 7'b0000110;
4'hf: seg = 7'b0001110;
endcase
endmodule
    zhangchao
