Mar 20, 2012 #1 S sharma46 Newbie level 6 Joined Mar 20, 2012 Messages 14 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,283 Activity points 1,384 wt is the header file used for controller at89s52? wt is the way to define a bit in at89s52? can i use flash magic burner to burn the hex program of at89s52?
Mar 20, 2012 #2 A aameer Full Member level 4 Joined May 12, 2010 Messages 216 Helped 33 Reputation 64 Reaction score 32 Trophy points 1,308 Location Bangalore Activity points 2,503 you can use #include<reg51.h> or #include <REGX52.h> yes you can programmed the controller Flash Magic burner
Mar 20, 2012 #3 S sharma46 Newbie level 6 Joined Mar 20, 2012 Messages 14 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,283 Activity points 1,384 aameer said: you can use #include<reg51.h> or #include <REGX52.h> yes you can programmed the controller Flash Magic burner Click to expand... can you tell me how to adress a pin of at89s52 is it the same method we use in microcontroller like sbit en p2^3 or bit pinb p0.2
Mar 21, 2012 #4 A aameer Full Member level 4 Joined May 12, 2010 Messages 216 Helped 33 Reputation 64 Reaction score 32 Trophy points 1,308 Location Bangalore Activity points 2,503 Everything is same only your Controller changes.. Do Programming as you did for AT89s51/AT89C51... IF you are using Keil u Vision... All the Best
