orhanli1
Junior Member level 1
Just the opposite is true:hi,
i think it is a band Pass (BP) filter as the first op-amp is a low-pass filter and the second op-amp looks like a high-pass filter.In between freqency will pass through making it a band-pass filter. not sure about the 2nd circuit though.
i think the first is second order high pass and the second is second order low pass but ican't be sure
* The first stage is a high pass (High frequencies can pass the series capacitors and low frequencies cannot)
* The 2nd stage is a low pass (high frequencies are attenuated (a) in the grounded cap and (b) due to the negative and capacitive feedback ).
---------- Post added at 13:08 ---------- Previous post was at 13:05 ----------
However, the combination equals a good and reasonable bandpass only in case the highpass corner frequency is lower than the corner of the lowpass.
Since no element values are given, the question cannot be answered finally.
