I have some problem with my xilinx 12.1 software
velu.plg
Member level 5
Member level 5
chennai
i have some problem with my xilinx 12.1 software
during check syntax process (for any simple programs) it gives failer response
this is my and gate program....
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity a is
    Port ( a : in  STD_LOGIC;
           b : in  STD_LOGIC;
           c : out  STD_LOGIC);
end a;
architecture Behavioral of a is
begin
c <= a and b;
end Behavioral;
error:
Started : "Check Syntax for a".
INFO:HDLCompiler:1061 - Parsing VHDL file "F:/vlsi project/AV00 _samplecode/vhdl basic/test/a.vhdl" into library work
INFO:projectMgmt:656 - Parsing design hierarchy completed successfully.
Running xst...
Command Line: xst -intstyle ise -ifn {F:/vlsi project/AV00 _samplecode/vhdl basic/test/a.xst} -ofn a.stx
* HDL Compilation *
Compiling vhdl file "F:/vlsi project/AV00 _samplecode/vhdl basic/test/a.vhdl" in Library work.
Entity <a> compiled.
Entity <a> (Architecture <Behavioral>) compiled.
Process "Check Syntax" failed
Re: problem with xilinx .....................
You cant have the entity called a and a port called a in the same entity
No syntax error visible. There should be an error line and a qualified error messsage.
May be your tool doesn't like the entity name repeated as a port name.
now i change my entity name , but error is their.
entity test12 is
           b : in  STD_LOGIC;
           c : out  STD_LOGIC);
end test12;
architecture Behavioral of test12 is
begin
c <= a and b;
end Behavioral;
Assuming you have the std logic 1164 package included, there is no syntax error. Are you sure this is the only code in the project
