I have a problem with the keypad 4*4
didyi
I have a little problem with the keyboard 16 keys
I have a model where it's planted a pic 16f690 a 16 * 4 LCD and keyboard (keypad) 4 * 4
I wrote a script that displays on the LCD any texts
now I want to use the keyboard to display by exemple '1' if I press it shows 1 on the lcd ..ect
so for now I have not really started this script
I just tried to find the logic to do it
I know that the keypad is a 4 * 4 matrix
I put the bits associated with the input lines
and those of the columns as outputs
I have the Keypad is linked with the port C
I did
main
bsf PORTC, 0
btfsc PORTC, 4
call LWD_Write1
goto hand
this script is just to test if what i want to do is going to work or no,
if any one of you have ideas or scripts that can help me I will be grateful
Have a nice week end
Enable the pullups at the inputs.
Then set all outputs to high impedance
Set one output low, wait a bit, then read the inputs.
Then set the next output low and all other outputs to high impedance.
Wait. Read....and so on.
Every pressed button will result in a low.
Only one button may be pressed.
Klaus
Reactions: didyi
    didyi
Hello
HTML:
	bsf STATUS,RP0 				;bank 1
		bcf STATUS,RP1
		bcf OPTION_REG,7	; Enable the pull up
		bsf		STATUS,RP0
		bsf		STATUS,RP1	; Selection bank 3
		movlw	0xF0			;configuration du port
		movwf	TRISC
		bcf	STATUS,RP0
		movlw	0xF0			;
		movwf	PORTC
		bcf PORTC,Col1
		call Wait5us
		btfsc	PORTC,Lin1
		call Ecrire
This is what i did
HTML:
Lin1	EQU	0
Lin2	EQU	1
Col1	EQU	4
Col2	EQU	5
Col3	EQU	6
Col4	EQU	7
Lin3	EQU	3
Lin4	EQU	2
and i made those subroutines
Ecrire
HTML:
		movlw '*'
		call LCD_Write
                return
Wait5us
HTML:
nop
		nop
		nop
		return
i did that just to test before doing the code to scan all the keypad
Thank you
Keypad 4*4 pic16f690
Hi everyone
i wrote a script to scan a keypad normaly it woorks
i only have one probleme is for exemple if i press 1 it appears a lot of 1's it depends about how much i let my finger on the button.
i wanted to enable the pull ups i found that on OPTION_REG but it only enables the pull up for the portB and A but my keypad is attatched with the port C
so if any one of you have an idea about how i'm going to fix that i'll be greatful.
its a week now that i'm trying to fix it.
this the code that i wrote
#include p16f690.inc
#include Adressage.inc
		extern	LCD_CLEAR,INITLCD,LCD_Position,LCD_Write,Cycle_Write,Conv_ASCII,LCD_Position
	org 0x00
			CMP		equ		0x34
			call		INIT
			call		INITLCD
			call			LCD_CLEAR
			movlw		0x00
			call			LCD_Position
		bcf STATUS,RP1
		;bcf OPTION_REG,7	; Enable the pull up
		;bcf		STATUS,RP0 ; en mettant les pin en entrée analogique active le pull up
		;movlw	0xFF
		;movwf	ANSEL
		bsf		STATUS,RP0
		movwf	TRISC
		bcf	STATUS,RP0
debut
		movlw	0xFF			;
		movwf	PORTC
		call	Wait2s
		bcf PORTC,Lin1			;
		call Wait2s
		goto test_cols
Ligne2
		bsf PORTC,Lin1
		bcf PORTC,Lin2
		call Wait2s
		goto test_cols2
Ligne3
		bsf PORTC,Lin2
		bcf PORTC,Lin3
		call Wait2s
		goto test_cols3
Ligne4
		bsf PORTC,Lin3
		bcf PORTC,Lin4
		call Wait2s
		goto test_cols4
tout_à_1
		bsf  PORTC,Lin4
		goto debut
Ecrire1
		movlw	'1'
		call	LCD_Write
		goto debut
Ecrire2
		movlw	'2'
		call LCD_Write
		goto debut
Ecrire3
		movlw	'3'
		call LCD_Write
		goto debut
Ecrire4
		movlw	'4'
		call	LCD_Write
		goto debut
Ecrire5
		movlw	'5'
		call LCD_Write
		goto debut
Ecrire6
		movlw	'6'
		call LCD_Write
		goto debut
Ecrire7
		movlw	'7'
		call	LCD_Write
		goto debut
Ecrire8
		movlw	'8'
		call LCD_Write
		goto debut
Ecrire9
		movlw	'9'
		call LCD_Write
		goto debut
Ecrire0
		movlw '0'
		call LCD_Write
		goto debut
dep_cur_droit
		addlw	0x02
		call	LCD_Position
		goto debut
dep_cur_gauche
		sublw	0x01
		call	LCD_Position
		goto debut
dep_cur_haut
		addlw	0x40
		call	LCD_Position
		goto debut
dep_cur_bas
		sublw	0x40
		call	LCD_Position
		goto debut
test_cols
		btfss PORTC,Col1
		goto	Ecrire1
		;btfss	PORTC,Col2
		;goto	Ecrire2
		btfss	PORTC,Col4
		goto	dep_cur_droit
		btfss	PORTC,Col3
		goto	Ecrire3
		btfsc	PORTC,Col3
		goto	Ligne2
test_cols2
		btfss PORTC,Col1
		goto	Ecrire4
		;btfss	PORTC,Col2
		;goto	Ecrire5
		btfss	PORTC,Col4
		goto	dep_cur_gauche
		btfss	PORTC,Col3
		goto	Ecrire6
		btfsc	PORTC,Col3
		goto	Ligne3
test_cols3
		btfss PORTC,Col1
		goto	Ecrire7
		;btfss	PORTC,Col2
		;goto	Ecrire8
		btfss	PORTC,Col4
		goto	dep_cur_haut
		btfss	PORTC,Col3
		goto	Ecrire9
		btfsc	PORTC,Col3
		goto	Ligne4
test_cols4
		;btfss	PORTC,Col2
		;call	Ecrire0
		;btfsc	PORTC,Col2
		btfss	PORTC,Col4
		goto	dep_cur_bas
		goto	tout_à_1
Fin
			goto	Fin
; ------------------------ INIT
INIT
		bcf		STATUS,RP0
		bcf		STATUS,RP1	; Selection bank
		clrf    	PORTA			; init PORTA
		clrf		PORTB			; Init PORTB
		clrf		PORTC			; Init PORTC
		bsf		STATUS,RP0
		movlw	0x00			;Parametrage PORTA
		movwf	TRISA
		movlw	0x00			; Parametrage PORTB	0x_0
		movwf 	TRISB
		movlw	0xF0			; Parametrage PORTC 0xF_
		movwf	TRISC
		bcf		STATUS,RP0	; Bank 2
		clrf		ANSEL
		clrf		ANSELH
		bcf		STATUS,RP1
		return
Ecrire
		movlw '*'
		call LCD_Write
		movlw 0x43
		call LCD_Write
		return
Wait2s
		movlw	0xFF
		movwf	CMP
loop	nop
		nop
		nop
		nop
		nop					;1u
		decfsz	CMP,1		;1us  2 si CMP=0
		goto loop			;3us
		return
	end
This is quite expectable. You run a loop.. and every time it scans the keys.. it detects the key "1" pressed .. and outputs the "1" to the display.
With the pullups I can´t help you, because I don´t know details about the PICs.
Klaus
