tcwxiaoba
/home/cwtan 6 = PDRACULA
/home/cad/cadence/ic5141/tools/dracula/bin/32bit/PDRACULA: error while loading shared libraries: libm.so.6: cannot open shared object file: No such file or directory
/home/cwtan 7 = /home/cad/cadence/ic5141/tools/dracula/bin/64bit/PDRACULA
*/N* DRACULA3 (REV. 4.9_64.06-2006 / LNX64 /GENDATE: 6-JUN/2006 )
*** ( Copyright 1995, Cadence ) ***
*/N* EXEC TIME =21:04:17 DATE =17-DEC-2009 HOSTNAME = icserver
:/g drc.ev
** NOTE : CHECKING FOR DIMENSION: 100.000 MIC WHICH IS GREATER THAN:
90.000 CAN POTENTIALLY BE A PROBLEM FOR VERY DENSE LAYERS
:/f
** NOTE : DEFAULTING SCALEOUT TO: 0.001000000 MIC
** CREATING : COMMAND FILE : jxrun.com
** NOTE : THIS JOB HAS 110 STAGES
END OF DRACULA COMPILATIONS
* 0.129 Mbytes allocated to the current process.
* 0.129 Mbytes is still in use.
* THE END OF PROGRAM TIME = 21:04:31 DATE =17-DEC-2009 *
/home/cwtan 8 = jxrun.com
ulimit: Command not found.
CREATED ON 17-DEC-2009 21:04:17 PDRACULA REV 4.9_64.06-2006 301
0.164u 0.136s 0:00.34 85.2% 0+0k 0+0io 0pf+0w
/home/cad/cadence/ic5141/tools/dracula/bin/32bit/DRACLM: error while loading shared libraries: libm.so.6: cannot open shared object file: No such file or directory
/home/cwtan 9 = /home/cad/cadence/ic5141/tools/dracula/bin/32bit/DRACLM jxrun.com
*END
/home/cad/cadence/ic5141/tools/dracula/bin/32bit/GDS2IN: error while loading shared libraries: libm.so.6: cannot open shared object file: No such file or directory
thanks for you answer!
:/g drc.ev
:/f
*END
