Register Log in
i don't know which pin is the red output, the blue output, and the green output.
dl09
Full Member level 4
i have been reading the datasheet for ov7670 camera module. which pin is the red signal? which pin is the green signal? which pin is the blue signal? i have read the datasheet, and it is not clear which pin is the red signal, which pin is the green signal, and which pin is the blue signal.
FvM
Super Moderator
Staff member
Bochum, Germany
The output is 8-bit digital video, no dedicated pins for RGB signals.
KlausST
Super Moderator
Staff member
see Fig 11 and 12.
If you don´t understand them, then maybe it´s just a bit too early for you to access a camera.
Start with much more simpler projects.
First learn to go before try to run.
Klaus
dl09
Full Member level 4
rgb 565 is a format? and the camera module can be set to this format?
KlausST
Super Moderator
Staff member
Trust the datasheet.
Klaus
dl09
Full Member level 4
"trust the datasheet" that means it is a format?
betwixt
Super Moderator
Staff member
Aberdyfi, West Wales, UK
The information you need is in figure 11 of the data sheet. There is no Red, Green, Blue output as such, each is digitized then the digitized value is read out across two bytes as shown in the diagram. Your software/hardware has to produce the control signals to the OV7670 then at the correct time, read the bytes from the pins to reconstruct the RGB values.
Brian.
KlausST
Super Moderator
Staff member
The datasheet says so. Several times. Why do you ask?
Klaus
Toggle Sidebar
