You don't see any layers because the expected layout is inside the cell with the red box.
Use the combination shift+f (to view the layers) and ctrl+f (to go back to the current view).
You -are- seeing one layer. "instance/drawing". Try pressing "F"
(w/ shift) for "full" / display all levels) or Options>Display and
set view levels to 20 deep or something.
From your screen I see also that You haven't loaded correct display.drc so most probably after "shift-f" You will see nothing or each layer with the same pattern/collor.
Somewhere in your pdk should be default display.drc file, You can easily import it in your layers editor.
