Register Log in
I cannot power that pelletier module
rompelstilchen
Full Member level 2
fdsf
I cannot power that pelletier module : TEC2-25408
Hello,
I have tried to power that pelletier module with an AT power supply but I reached max -10°C or something
so I ordered a 12V 10A power supply,
as I measure the pelletier module, it really does not go up to specs
barely -20°C (should <-30°C) and current is only half of the specified current
pelletier:
https://www.aliexpress.com/item/32386272344.html?spm=a2g0s.12269583.0.0.662f6f04RWvMLA
power supply:
https://www.aliexpress.com/item/32990203636.html?spm=a2g0s.9042311.0.0.3da24c4d7hBp9i
fan: I am using a 12V fan with a 10x10x4cm CPU fan
what am I missing ?
sheers
FvM
Super Moderator
Staff member
Bochum, Germany
Do you have a full datasheet with I/V/ΔT curves? What's the expected hot side temperature for -30° cold side? Did you check the actual temperature?
Most likely problem is insufficient heat sinking at the hot side.
rompelstilchen
Full Member level 2
fdsf
yes, checked the temp with an ir temp "gun"
I am indeed building a bigger cooler/double fan apartus :)
FvM
Super Moderator
Staff member
Bochum, Germany
It's generally no good idea to operate a peltier element with fixed voltage supply because for each combination of heat sink thermal resistance, ambient temperature and pumped power there's an optimal operation current respectively voltage.
Said TEC2-25408 may need higher voltage, e.g. 14 or 15 V.
rompelstilchen
Full Member level 2
fdsf
I can try many different voltages
yet, finding datasheets is not easy
schmitt trigger
Advanced Member level 5
After all is done and said, this is a thermodynamic problem.
-What is the fan’s airflow and under what static pressure?
-What is the heatsink’s thermal resistance, with the calculated airflow?
-What is the heatsink’s ambient temperature?
-How many calories, joules, BTUs (or whatever thermal unit you wish to use) is the peltier module rated for? How does that compare to your thermal load?
-What are the peltier’s losses, which the heatsink will also dissipate?
Easy peasy
Melbourne
without calculating the heatsinks required for each side and the watts you are ( hopefully ) shifting off the hot side - you are operating blind - very tricky to arrive at a useful working arrangement under this approach ...
Toggle Sidebar
Design Fast
