Please help me understand what is going wrong with my importing. I am trying to import a 0402 100pF capacitor from Murata into ADS. I am suppose to get a bunch of components with pins connected after the import, but I do not, I only get pin 1 and pin 2. Here are some pictures of the process I do to import the file below. Idk if it has to do with the file type (.mod file), or something is wrong with my computer. Please help when you can, thanks!
I just wanted to know why it isn't working. I had it working before, but idk what thing i did different that would show the whole netlist, all i see now is the netlist display simulator and two pins that aren't even connected to anything. Thanks though, ill try it your way if I can't figure this other method out.
Well at least I obtained the other parasitic components, but now all the components are connected to ground as shown in the figure 1. I also get an error when I simulated the component as shown in figure 2. I was hoping your way would solve the issue, but i guess not, I get a different issue now.
