HYPERTERMINAL WITH NOKIA 6210
creative_35
Full Member level 1
Under Mango Tree
how to hyperterminal 6210
HI FRIENDS,
I need a circuit diagram to conect nokia 6210 to hyperterminal. I searched the website and found some DIY DLR cable circuit with a 16F84 PIC. Do I need a micro controller to connect to hyperterminal? I am confused. pls help me.
nokia 6210 data cable pin diagram
do NOKIA 6210 comes with data cable???
i mean dat if u can get the data cable for ur cellphone then u dont need any microcontroller.just connect mobile through data cable to serial port of computer.
otherwise search for pinouts of Nokia 6210 data cable and connect its RX,TX and ground pins to TX,RX,ground pins of computer respectively.
nokia 6210 cable circuit
Thanks for the replay,
I don't have a data cable. But I found a data cable circuit (DLR3P)from **broken link removed** This website. the circuit includes a 16F84 PIC and it confused me. what pic is doing in that circuit. and is it necessory for connecting 6210 to hyperterminal?
hyper terminal untuk nokia
Well the 16f84 there is a protocol converter. you need it because you cannot interface directly with a 6210 unless you are familiar with f-bus, but if you intended to use ordinary uart communication protocol then I also suggest you to use the dlr3 converter. The maxim IC is also useful because the level of 6210 is just 3.3 volts, so if you intend to use a 5 v level yu better convert it.
