Hummingbird Algorithm nexys 2 500(FPGA Implementation)
leohawk88
Newbie level 3
Newbie level 3
Hi all,
I need some help with hummingbird cryptographic algorithm. I have developed the ecryption and decryption in ise 12.3.
I need help with implementing it on the FPGA nexys 2 xcs500. My output's are assigned to the LED's. But it does not match the simulation. Every time I program the .bit file through adept, my results keep changing on the board(led's outputs are not fixed and keep changing).
I thought the issue was with the clock which is fixed at 50Mhz. I used a divider to run at 1Mhz. Now my output remains the same but is not matching the simulation.
I am new to VHDL, forgive me for any wrong technical terms or phrases.
Please help ASAP.
Thanks in advance.
Leo
How have you divided the clock? did you write a clock divider (bad) or use clock enables (good)?
How about posting some code and talking about specific problems.
Hi Tricky,
Thanks for such a prompt reply. My clock divider is as follows,
divideclock: process(clk)
variable divider : std_logic_vector(7 downto 0):="00000000";
Variable sig: std_logic:='0';
begin
if( clk='1' and clk'EVENT) then
divider := divider + '1';
end if;
if(divider=00110010)then
clock <= not sig;
divider:="00000000";
end if;
end process;
yes, thats the bad method.
But in your code clock is constant '1', because sig is never set to anything
But you should create clock enables instead, not an actual clock.
Tricky,
I am working on clock enable and will implement it soon. May I ask you to provide me with some resources or links on clock enable. In the mean time, I will search on my own as well.
Thanks again
Leo
Clock enables are just a signal generated that will enable a circuit for a specified period of time. You run the circuit using the system clock, but you only enable it for, say, 1 in every 3 clocks.
Here is an example using a counter to generate a 1/4 clock enable
signal cnt : unsigned(1 downto 0);
process(clk, reset)
begin
  if reset = '1' then
    cnt <= "00";
  elsif rising_edge(clk) then
    if cnt = 0 then
       --do something once every 4 clocks
    end if;
    cnt <= cnt + 1;
  end if;
end process;
