Huge skew on clock network
kumar_eee
Advanced Member level 3
Bangalore,India
Lets say I've met the Timing requirements ( both setup & hold in all the corners). But I've a large skew in my clock. Should I care about it?
wizard
Member level 3
China Mainland
If your clock network is big, large skew is possible. OCV mode is harder to meet. Since your timing has already closed, it is ok.
phoenixpavan
Full Member level 4
Bangalore
Hi Kumar,
As skew is considered only for timing analysis and both setup and hold are being met....it becomes insignificant.
ebuddy
Full Member level 3
The only thing I want to add is that make sure the reason for the "huge skew" is well understood. Whatever the number you got from the tools has to be carefully examined to make sure the number makes sense.
