Huge difference between simulation results of the schematic and the layout on ADS
mayjailomo
Newbie level 5
Hi all,
I am recently designing a 5.8GHz wilkinson power divider. FR4 will be used in this design and the thickness of the substrate is 0.8mm. Here is the schematic of the power divider:
The resonant frequency is at 5.8GHz for S11 after fine tunning some parameters. However, with the same parameters, the resonant frequency is shifted in the momentum co-simulation. As i believe that momentum co-simulation provides a more reliable simulation result, i tuned the parameters so that the simulation result of the resonant frequency of S11 is at 5.8GHz in momentum co-simulation.
Final simulation result of the schematic:
Final simulation result in momentum co-simulation:
However, after I fabricated the coupler. The measured result is very different from the result in momentum co-simulation. And it has a higher similarity with the simulation result of the schematic.
Does anyone know the reason? Thank you for your time.
Here is the link of the workspace: shorturl.at/ntDO1 (Onedrive)
The ripple seen in the measurement suggests that a large resonant structure is involved. I suspect an unsuitable PCB to cable interface and respective sheet waves.
Regarding systematic deviation between simulation and measurement, huge uncertainty of regular FR4 Er requires an empirical adjustment of PCB parameters according to measurements.
FR-4 Material may show up pretty much variation by supplier and lot by lot.
It's not suitable for critical 5.8GHz applications.
Thanks for your reply. I understand that FR-4 is only suitable for low frequency applications, but there is budget limiation for this device so I have no choice.
Thanks for your advice. I will resolder the SMA connector to see if I can obtain a better result. So do you think the deviation between simulatio result of layout and schematic is also because of the uncertainty of dielectric constant of FR4? I am worry that that's because I didn't setup the simulation correctly.
I also believe there are some layout issues, can you post your layout here ?? Let's discuss..
Where is your balancing resistor ?? It's missing.
You have to place a resistor in simulation schematic to simulate your layout.
You placed two pins only..
