be_jouster
Junior Member level 1
Hi all,
Currently I designing 16-channel rc servo driver. For now i just try for 2-channel only. As my hardware, I'm using 18F2331 and 10Mhz osc. I'm coded my firmware using ASM. I hook-up the output pin to the scope. The result as below:
1) 10Mhz osc with HSPLL enable - There is a signal on the scope but not as I programmed it to be. Sometimes my mcu like hang or something else.
2) 10Mhz osc without HSPLL - There is a signal on the scope as I programmed it to be. In term of time, it is 4 times bigger as my program target for 40Mhz operation.
Why could this happen? I really needs to run my firmware at 40Mhz to support 16 servos. Anyone know how to resolve this problem?
Thanks.
Thanks.
