Hspice waveform problem
an_82
Member level 2
Delft, Netherlands
Hello all,
I simulated a circuit in HSpice 2008. The problem is that the output waveform is not accurate and is segmented. Please see the attached picture.
I used smaller step in .tran analysis, but it does not correct:
.tran 1n 2u
This problem does not exist in Hspice 2003.
FvM
Super Moderator
Staff member
Bochum, Germany
Hard to say without seeing a circuit or waveform time scale. Besides minimal transient time step parameter, the result many be also affected by absolute and relative accuracy parameters. Different default parameters may cause the version difference.
an_82
Member level 2
Delft, Netherlands
Dear FvM,
I increased the time (lower frequency), but it does not change. It is interesting that the same Netlist is simulated correctly in 2003 !!
BigBoss
Advanced Member level 5
Turkey
Minimum Time Step parameters should be changed.
