HSPICE use output as an input
junsik
Junior Member level 2
Hi I am studying HSPICE.
I want to reuse the result as an input variable like controlled source(current controlled voltage source).
For example, if assume the current I1 flows through resistance R1, I want to use the I1^2 in the current controlled voltage source.
I think 'par' should be used. but I don't know the details.
Please help me. Thank you
Behavioral Voltage Source
[General Syntax]
Exxx n+ n- VOL=’equation’ <MAX>=val> <MIN=val>
[For your Case]
E1 n1 n2 VOL=’I(R1)*I(R1)’
Reactions: junsik
    junsik
