HSpice simulation for getting the vref variation
jc2
Member level 3
**********FIRST SIMULATION********
.temp 27
.dc temp -25 125 1
.print vref
********SECOND SIMULATION********
.dc temp -25 125 1
.print vref
The vref variation in the first simulation is very diferent to the vref variation in the second simulation.
Why does HSpice get diferent results between the two simulations?.
Which is the correct simulation for getting the vref variation?
What is the function of .temp?
thanks
hspice .temp
There should not be aby difference in the two simulations.If you do not define .temp 27 , then Hspice should take the default value.In the .DC simulation, the OP would be done for each value of the DC step.Any comments?
    jc2
spice simulation .temp
Hi
maybe it relates to tref or tnom options.
see hspice user manual.
regards
    jc2
hspice temp
.temp 27
.dc temp -25 125 1
.print vref
.dc temp -25 125 1
.print vref
thanks
I agree with dhasmana, there should not be any difference.
If I write in the simulation script .temp -25 or .temp 125, HSpice shows the same vref variation of the simulation with .temp 27(FIST SIMULATION).
What do I have to do?
thanks
.temp in hspice
.temp defines the operating temperature of your circuit. There is no correct result, it all depends on your application.
In your case however, it is interesting point. Did you see the manual, what did it say?
I think it is not the .temp which is problematic. The .DC command should be looked at, may be the temperature should not be defined this way.
Cheers
Re: .temp HSpice
.temp 27
.dc temp -25 125 1
.print vref
.dc temp -25 125 1
.print vref
thanks
I don't know what the problem is. Maybe, it's not possible to use .temp and .dc temp together.
thanks
