hspice file handling operations
rajee
Newbie level 5
Newbie level 5
Whether we can call a .sp file inside another hspice
file other than model parameters. If so how to do that.
If I am having nand gate file and if have to call inverter file from outside, along with .include command how I can use the inverter file inside the nand file.
.inc "full_path_to_inverter_file_name"
Inside your NAND-file you call an inverter e.g. by
Xinv1 in-node out-node INV wp=3u wn=1u
... if your inverter definition or subcell/macro is INV . wp/wn may be specified depending on the subcell definition.
Reactions: rajee
    rajee
I am not having subcell or macro . Iam having only a inverter file with t he name inverter.sp. whether I have to make the inverter with subcircuit model and give the subcell name?
