Jan 28, 2008 #1 ehsan_r34 Member level 2 Joined Apr 1, 2007 Messages 45 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,288 Activity points 1,555 Hspice error Please tell me why the following error occured in Hspice? my circuit is a switched cap circuit. " **error**: internal timestep too small in transient analysis" Please answer me as soon as possible. Thanx Added after 2 hours 19 minutes: Can i increase the resolution of the analysis of Hspice?
Jan 29, 2008 #2 R renwl Advanced Member level 1 Joined Apr 26, 2004 Messages 452 Helped 27 Reputation 54 Reaction score 5 Trophy points 1,298 Location shanghai,china Activity points 1,805 Hspice error it's the convergence problem. i suggest you use the spectre as simulator to simulate switch cap circuit.
Jan 29, 2008 #3 A analog_prodigy Full Member level 2 Joined Jul 19, 2007 Messages 140 Helped 14 Reputation 28 Reaction score 2 Trophy points 1,298 Location India Activity points 1,936 Hspice error Increase the no of points in the .options statement Added after 19 seconds: THis will solve your convergence issue
Jan 30, 2008 #4 T test_123 Junior Member level 3 Joined Jul 31, 2007 Messages 28 Helped 4 Reputation 8 Reaction score 0 Trophy points 1,281 Activity points 1,400 Hspice error try to give some initial condition
Jan 30, 2008 #5 T tlihu Full Member level 6 Joined Jan 2, 2002 Messages 335 Helped 19 Reputation 42 Reaction score 13 Trophy points 1,298 Activity points 2,259 Hspice error Add .ic or .nodeset can help.
Jan 30, 2008 #6 Y yibinhsieh Full Member level 4 Joined Apr 25, 2005 Messages 194 Helped 19 Reputation 38 Reaction score 5 Trophy points 1,298 Activity points 2,845 Re: Hspice error In SC circuits, this kind of error often be appeared in Hspice simulation. You can add initial condition (.IC) or use large GMINDC (GMINDC>1e-9). Good luck
Jan 30, 2008 #7 C crystalballs Member level 1 Joined Jan 10, 2008 Messages 32 Helped 6 Reputation 12 Reaction score 4 Trophy points 1,288 Activity points 1,479 Re: Hspice error ehsan_r34 said: Please tell me why the following error occured in Hspice? my circuit is a switched cap circuit. " **error**: internal timestep too small in transient analysis" Added after 2 hours 19 minutes: try with gshunt and cshunt options Click to expand...
Jan 31, 2008 #8 P poweric Member level 5 Joined Oct 29, 2006 Messages 80 Helped 3 Reputation 6 Reaction score 0 Trophy points 1,286 Activity points 1,733 Hspice error you may use method=gear
Feb 1, 2008 #9 Q q0w1e2r3 Junior Member level 1 Joined Jul 8, 2006 Messages 19 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,388 Re: Hspice error you can select .option for help
