[SOLVED] HSpice and Nangate 45nm Open Cell Library 2010
r_usso
Newbie level 6
Hello Everyone,
I have a question. When I am using NangateOpenCellLibrary_PDKv1_3_v2009_07 with Hspice, I am selecting the following file as library.
.INCLUDE 'C:\synopsys\NangateOpenCellLibrary_PDKv1_3_v2009_07\technology\models\hspice\hspice_nom.include'
But when using NangateOpenCellLibrary_PDKv1_3_v2010_12, I can not find that file. What should I select in this case? I have tried to use the following file:
.INCLUDE 'C:\synopsys\NangateOpenCellLibrary_PDKv1_3_v2010_12\Back_End\spice\NangateOpenCellLibrary.spi'
But it shows NMOS_VTL not find error.
Which file should I use to include the library?
If the NMOS_VTL was found in the older library, try to include both library files!
Thank you for your reply. When I try to add both the library, it shows the following error:
hnw error: (c:\users\russo\copy\study thesis\tests\final\not\not.sp:40)
definition INV_X1 redeclared. This was previously declared at
(C:\synopsys\NangateOpenCellLibrary_PDKv1_3_v2010_12\Back_End\spice\NangateOpenCellLibrary.spi:2232)
Error: (c:\users\russo\copy\study thesis\tests\final\not\not.sp:40) hnw error
# : net error
... redeclared. This was previously declared ...
Redeclaration error. So copy the older library to a lib file with a new name, then remove all the models which are already declared in the newer lib file, and again .INCLUDE both libs (the rest lib and the new one).
Or copy the newer lib to a lib file with a new name, and copy and paste the missing models from the older lib into this copied lib file. .INCLUDE just this one.
Reactions: r_usso
    r_usso
Hello, I have included only the NMOS_VTL and PMOS_VTL from the old library:
.OPTION POST
.INCLUDE 'C:\synopsys\NangateOpenCellLibrary_PDKv1_3_v2009_07\technology\models\hspice\tran_models\models_nom\NMOS_VTL.inc'
.INCLUDE 'C:\synopsys\NangateOpenCellLibrary_PDKv1_3_v2009_07\technology\models\hspice\tran_models\models_nom\PMOS_VTL.inc'
But Now it shows the following error:
hnw error: (c:\users\russo\copy\study thesis\tests\final\not\not.sp:39)
Error: (c:\users\russo\copy\study thesis\tests\final\not\not.sp:39) hnw error
# : net error
Ok, Problem solved. I had to remove the .subcircuit declaration from my code.
