hsim error: segmentation violation, aborting…
rhearao
Newbie level 2
Hi guys,
"error: segmentation violation, aborting… " happens when I use hsim to run flash memory fullchip simulation. Has anyone ever met this issue before?
if I set the global precision to 1) hsimspeed=3 hsimspice=0 hsimanalog=0 It will use up all memory and terminate at ~90%
2) or set: hsimspeed=3 hsimspice=1 hsimanalog=1 The output is "error: segmentation violation, aborting… "
3) otherwise set: hsimspeed=4 hsimspice=0 hsimanalog=0 or lower precision The simulation would finish but the function is not accurate enough.
Looking forward to any kindly reply!
Thanks.
erikl
Super Moderator
Staff member
Germany
Segmentation violation usually also means "short of memory" (data segment runs into code segment). Try to spend more memory -- if only virtual memory -- for your sim. process!
rhearao
Newbie level 2
while simulating it only used about 5% memory (total 74G ), I think memory is enough for the simulation.
It's wield that I can run FF corner seperately, but if I use .alter in the .sp file the simulation will`` terminate.
for example
: xxx.lib tt
xxx
.alter
xxx.lib ff
xxx
.alter
xxx.lib ss
xxx
---------- Post added at 23:08 ---------- Previous post was at 22:41 ----------
for example
: xxx.lib tt
xxx
.alter
xxx.lib ff
xxx
.alter
xxx.lib ss
xxx
