hread command in vhdl
Junior Member level 2
what is the syntax of hread in vhdl....
can someone explain its use with a simple example
What is hread? Not a member of a common VHDL package as far as I'm aware of.
procedure HREAD(L:inout LINE; VALUE:eek:ut STD_LOGIC_VECTOR);
from STD_LOGIC_TEXTIO library (overloads STD_TEXTIO library)
yes it is a command in vhdl
O.K., HREAD (=hexread) is a function from stdlogic_texio, a non-standard Synopsys library.
In 2008, read, oread and hread (along with respective write procedures) are added for all standard types and are added to their respective libraries - so hread for std_logic_vector exists in the std_logic_1164 library.
