How We Can Assemble A Epson Printer head
reza17
Junior Member level 3
repair print head lq-2180
hi
I Have A Problem With A Dot Matrix Epson Printer " LQ-2180"
Can You Help Me?
Are You Have An Instruction For Assebling PRINTER HEAD Of " LQ-2180 "
It Have Many Needle And Spring In It.
Thanks
sinip
Full Member level 4
Republika Srpska
reza17 said:
hi
Can You Help Me?
Thanks
I was about to respond to your previous question about how to disassembly it with "Don't even try to do that".
Well, now is too late...
reza17
hi
it is not any instruction on do this
please help !!!!!!
sinip
Full Member level 4
Republika Srpska
reza17 said:
hi
please help !!!!!!
Instruction is you should not have done that in the first place. And now, probably, the only thing you can do is send the printer to authorised EPSON service, or buy a new one. Good luck.
reza17
HI
I Dont Opened A Printhead
But I Want This Instruction For A Friend
I Want Only An Instruction To Opening And Closing A Printhead Of A Dot Matrix Printer " LQ-2180 "
An Step By Step Instruction .
Thanks
reza17
Hi
Thanks , But I Dont Want The Printer Service Manual
I Want An Ster By Step Instruction For Opening And Closing The Head Of The Printer
Opening And Closing Printer Head Is A Hard Work.
adil_shah
Newbie level 1
first of all i want to know how he opened the head if he opened it by hitting the head from back side towards front side from its heat sink than i m afread he must have damaged the head and if he opned it by a proper press than its ok reply me did he fine any broken pins from the head or its all right just an opened only if than sure i can help u don worry just write me back the ecact status of the head
thnx
mrbanners
Newbie level 5
algeria
this is the service manual LQ-2180
for disassembly check on this service manual LQ-2170 page 84
