How to write or read SD card in FAT32 format?
Deepak350
Member level 1
India
I have interfaced SD card to MCU. I can read and write to the sd card. But I want to read and write to the SD in FAT32 format.
Cheers
sdcard fat32
I have sent you a function set that can help you to implement FAT32/FAT16 in your Project.
You should review all the functions and modify it to adapt with your design.
Enjoy it.
sd to fat32
Thanks for your reply.
I will go through the code and see if I can use the logic!
Cheers
sd card fat32 file system
I have created a file and when I read the boot sector data, the file name should be in the boot sector (512 bytes) right? Boot sector shows that it is FAT32 and many more info.
Is there any other command to be initialised before getbootsector?
Cheers
sd sector fat32
Hello!
No, the name of the file you have created is not (or at least should not be)
in the boot sector.
The file name might be in the root sector (which is not the boot sector), or in
another sector in case your file is in a folder.
Dora.
Cheers
