How to write c code to collect data using wifi card
Kaka_fsk
Newbie level 5
wifi c++ example code
Hi, I am planning to write a code which will control wificard to communicate with other devices to do data transfer.
Could anyone pls give me some example code or any hint about controling the wifi card ?
Does Visual C++ have any ActiveX to do such work?
Thanks in advance.
how to using wifi with c++
Hi Kaka_fsk,
Writing codes to transfer data through WiFi is the same as
doing it through wire Ethernet.
They communication using IP address & port no.
You may try looking out for example code that
send data through TCP/IP & port.
These 2 component is also known as a socket connection.
Hope this is what you are looking for.
You may try researching for more information on these keyword.
Best Regards,
Siong Boon
    Kaka_fsk
