how to write 64 Bytes of data?
LatDrIvE
Member level 4
athens
hello all,
i would like to ask how i can load a memory ip with 4 packets of
64bytes of data using VHDL? i am looking for hints in coding style and
syntax.
regards
If you use Coregen, you can set some initial data when generating the memories.
the thing is that i have to use vhdl in order to load the memory block
Why don't you use array type which will be instantiated as a ram or rom.
A simple suggestion is that put the packet contents to the array at reset.
