How to work with matlab simulator?
electim2004
matlab
hi
please guide me to work with matlab.system simulation.
thank you
Re: matlab
it depends on the field you want to apply/simulate..
but, you can take a look in the follow website:
matlab
Try MATLAB's excellent online help:
Click the Help button -> Contents -> Simulink -> Getting Started.
Re: matlab
hi,
you can start by going through the book "Matlab programming for engineers" by "Stephen J. Chapman". You should go through the book chapter wise and write and run the example programs given in the book.
Re: matlab
search here matlab tutorials
matlab
I want use Mathlab for DSP can you help me!
Re: matlab
What DSP you want to do with MATLAB? MATLAB Help is always helpful for beginner and advance learner. It helps me a lot. You can have a try.
Re: matlab
This depend on the which you are wishing to simulate?
Say you want communications or DSP based algorithms use these two books
1) complementary communications by Proakis
2)DSP using matlab by proakis and Ingle .
These two books are really interesting and highly application oriented.
Use signals and systems by simon haykins which has both applications and matlab coding
If image processing use gonzales book
Re: matlab
hi all
well my ques ...is related with matlab only....
cany any one help in matlab formats...i want to reduce the gape b/w the bits in a no. e.g. 1 0 1 0 is the binary no. i want this no. as 1010..i.e. without the space b/w the bits..or vice versa.can i do so using matlab?
thanx in advance
Mona
matlab
on matlab, try to type in "demos" or search the Help menu for the demos you could check on, it will give you some insights on the applications that you could do on matlab and how to simulate them
Re: matlab
help is the best guide
Re: matlab
u refer the text book DSP using matlab by Ingle
Re: matlab
Matlab DSP is not very difficult. I have described 60Hz bandstop filter realisation for ECG signal in may page. There you can also find source code to download and try by yourself. I am plannig to put more related information about matlab DSP realisation. I guess it will be interesting for someone.
MM
http://www.scienceprog.com
Re: matlab
