How to work with 5x7 LED matrix and PIC16F87x series?
ZeleC
Full Member level 5
Hello ,
im trying to work with a two digit 5x7 matrix led .can any one give links or help on how to work it with a pic16f87x series in C language
thank you a lot
matrice led 7x5 en c
;5x7 LED Array test
; PORTB used to select row (0 is on, 1 is off)
; PORTC<4:5> used for data,clk of 74164 Shift Reg
list p=18F252
#include <P18F252.INC>
; constants
; Number of columns in the display
; to change the number of displays, change NCHARS
NCHARS equ d'6'
NSTRINGS equ d'27'
COLUMNS equ 5*NCHARS
DWELL_TIME equ d'9'
FontTable equ 0x01000
StringTable equ 0x00800
; variables
; Used as counters for displaying the rows
cblock 0x000
CurrentRow ; the row being displayed
CurrentString ; index of current string being displayed
CurrentColumn ; counts down from COLUMNS as chars are displayed
CurrentCharIndex ; index of character currently being displayed
CurrentCharData ; the character data to display
AdvanceWidth ; advance width for char being drawn
CurrentStrLen ; length of the current string
RowRingCounter ; holds the ring counter for the row display
DwellCounter ; how many iterations before scrolling
endc
; Used by the shift register write routine
cblock
ShiftReg ; Temp var to hold shifting byte in
ShiftBits ; number of bits to shift into shift reg
ShiftCounter ; Temp counter
endc
; Used to keep track of what string is being displayed
cblock
StringCharIndex ; index of current character in string
StringSubCharIndex ; index into current character in bits
endc
; Used for delay loops
cblock
DelayCountL
DelayCountH
endc
; Used in GetCharData subroutine
cblock
GCDTemp
endc
;program code starts here
org 00200h ; Beginning of program EPROM
Start
clrf LATB ; Clear PORTB output latch
clrf TRISB ; Make PORTB pins all outputs
clrf LATC ; init PORTC
movlw b'10001000'
movwf TRISC ; make most portc pins outputs
clrf CurrentString ; start with string 0
; Set up the string, char, subchar offsets here
clrf CurrentCharIndex
call GetStrChar ; get length byte (beginning of string)
movwf CurrentStrLen
movlw -NCHARS
movwf StringCharIndex
clrf StringSubCharIndex
setf LATB
ScrollLoop
movlw DWELL_TIME
movwf DwellCounter
; The same image gets displayed for DWELL_TIME iterations
DwellLoop
; reset if programming switch is set...
btfsc PORTC, 3
reset
Display7Rows
movlw b'10111111'
movwf RowRingCounter ; set up display of high bit row first
clrf CurrentRow
DisplayRow
movlw COLUMNS
movwf CurrentColumn
movf StringSubCharIndex,w
addwf CurrentColumn,f
movff StringCharIndex,CurrentCharIndex
DisplayChar
; lookup data for current char
movf CurrentCharIndex,w
call GetCharData
movlw 0x5
addwf AdvanceWidth,w
cpfsgt CurrentColumn
goto DisplayLastChar
movwf ShiftBits
movf CurrentCharData,w
call ShiftData
movlw 0x5
subwf CurrentColumn,f ; check for more columns to display
bz DisplayNextRow ; done if no columns left to display
incf CurrentCharIndex ; else go to next char
goto DisplayChar ; and repeat routine till done
DisplayLastChar
movff CurrentColumn,ShiftBits ; note: don't advance last char!
call ShiftData
DisplayNextRow
; Pause for long enough for somebody to see the data
movff RowRingCounter, LATB
call Delay
clrf LATB
comf LATB
rrncf RowRingCounter,f ; move to next row
incf CurrentRow
movlw 0x7
cpfseq CurrentRow
goto DisplayRow
DisplayRowsDone
decfsz DwellCounter
goto DwellLoop
call GetCharData
incf StringSubCharIndex
movlw 0x5
cpfseq StringSubCharIndex
goto ScrollLoop
incf StringCharIndex
movf CurrentStrLen, w
cpfseq StringCharIndex
goto ScrollLoop
incf CurrentString
movlw NSTRINGS
cpfslt CurrentString
clrf CurrentString
movwf CurrentStrLen
movlw -NCHARS
goto ScrollLoop
; Delay Subroutine
Delay
; return
clrf DelayCountL
Delay1
decfsz DelayCountL
goto Delay1
return
; ShiftData subroutine
; takes the byte in w and shifts it into the shift register
; shifts ShiftBits bits, starting with the MSB
ShiftData
movwf ShiftReg
movff ShiftBits, ShiftCounter
; test the last bit, put it into output bit
; we are inverting the output here
ShiftData_Loop
btfsc ShiftReg, 4
bsf LATC, 4
btfss ShiftReg, 4
bcf LATC, 4
; strobe the SR clock
bsf LATC, 5
bcf LATC, 5
; keep going until all 5 bits are shifted
rlncf ShiftReg, f
decfsz ShiftCounter,f
goto ShiftData_Loop
return
; GetStrChar routine
; return the CurrentCharIndex'th character from the string at
; index CurrentString (in w)
GetStrChar
movf CurrentString,w ; TBLPTRH:TBLPTRL gets string offset
mullw 0x40 ; (string starts at PRODH:pRODL)
movff PRODH, TBLPTRH
movf PRODL, w
addwf CurrentCharIndex,0 ; add current character offset back into w
movwf TBLPTRL
btfsc STATUS, C
incf TBLPTRH
movlw (StringTable>>8)&0xff ; add base offset of StringTable
addwf TBLPTRH ; high order
movlw StringTable&0xff
addwf TBLPTRL ; then low order byte
btfsc STATUS, C
incf TBLPTRH
tblrd* ; TABLAT gets character code
movf TABLAT,w ; return character code in w
return
; GetCharData subroutine
; returns character data of char at index w for row CurrentRow
; value returned in CurrentCharData
; **REPLACE THIS WITH SOMETHING SMARTER**
GetCharData
; Calculate offset of char in table
movwf GCDTemp
cpfslt GCDTemp
goto GetCharDataNull
movlw 0x00
cpfsgt GCDTemp
call GetCharDataFromTable
movwf CurrentCharData
return
GetCharDataNull
clrf CurrentCharData
clrf AdvanceWidth ; don't advance on null
return
call GetStrChar ; get next character
mullw 0x08 ; TBLPTRH:TBLPTRL get row data offset
movff PRODH, TBLPTRH ; (8 bytes/character)
movff PRODL, TBLPTRL
movf CurrentRow,w ; add in current row
addwf TBLPTRL
btfsc STATUS, C
incf TBLPTRH
movlw (FontTable>>8)&0xff ; then add FontTable base addr
addwf TBLPTRH
movlw FontTable&0xff
addwf TBLPTRL
btfsc STATUS, C
incf TBLPTRH
tblrd*
clrf AdvanceWidth ; set AdvanceWidth if this char
btfsc TABLAT, 5 ; requires an column extra space
incf AdvanceWidth
movf TABLAT, w
return
org StringTable
#include "text.asm"
org FontTable
#include "5x7.asm"
END ; directive indicates end of code
18f252 matrix led
You can download the rar file: PICBASIC Proton Code, PIC16F84A Proteus Simulation DSN Files, and VB developed by Oliver (VB exe is not mine). Can any body develop VB code with 7x5 10 LEDS matrix using pic16f877
18f252 led matrix project
hello,
you can find a whole dot matrix tutorial with code for pic 16f84 at :
for one module : **broken link removed**
for the whole project search the site.
have fun.
A. Abdel Hamid
vb 5x7 character
Look **broken link removed**
