aetosa
Member level 3
- Joined
- Jan 18, 2005
- Messages
- 63
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 546
I 've built a pcb for the NCP2824, the one at Figure 19, Single Ended Configuration, but I've not connected the control pin (pin C2 = CNTL) which should be connected with a microcontroler, because I thought I could use it without a microcontroler. But it seems that I can't, I think the microcontroler also 'wakes up' the ic.
What do you think, can I use it without a microcontroler?
Might help: schematic for the evaluation board.
Test Procedure for the NCP2824 Evaluation Board where it says "wake up test: J1 Must be connected to VDD". If I connect C2 pin at VDD it will 'wake up'?
