I have a Ramdom Number Generator, the output is like: 10010101000101010....
I need to verify whether it is truely ramdom or not, how can i do that? Can I use Matlab to do the job?
hi
u should regard some options in random number testing
i.e. PDF testing correlation and PSD testing
u should be careful about your period of repitation in your random number
hi
i can help u if i know what is your problem and what do u want to do
aften testing PDF and PSD is useful for testing Normal(guasian) random number
but your example is binary. test hist() function in matlab may be it help u
For binary, maybe you can try context-based arithmetic coding. You read the bit stream and create a big context table to count the occurance of all combination, within a maximum length, of course. After a long bitstream, if some contexts have a much bigger count than others, that is it.
A direct way to check if the sequency is truly random is to use auto-correlation function in MATLAB. A true random sequence should generate a Dirac type auto-correlation output, whose Fourier Transform should give you 'white' spectrum density function.
In matlab, you can use xcorr(A), where A is your random sequence to be analyzed.
