How to vary crystal frequency
demetal
Full Member level 5
Full Member level 5
Kingdom Of Kochi
Is there any possible method by which we can vary frequency of a crystal to few range.... for example.... can we generate 28.322Mhz from a 28 Mhz crystal by any additional circuit.... :roll:
Thanks
You can apply a capacitor across the crystal, this will change its frequency and is commonly used.
-Pb
Or an inductor will work but the amount by which you can 'pull' it is very small, probably no more than around 0.5% of it's fundamental frequency so you would be very unlikely to manage 322KHz from 28MHz (1.15%). You also lose some stability as you move further away form fundamental.
Brian.
The pulling range of usual crystals is below 1000 ppm respectively 0.1 %.
There's basically a direct inverse relationship between the stability/precision of a resonant element and its tuning range. Very high Q devices like crystals can only be pulled a tiny bit (hundreds of ppm, maybe 1000ppm if you're careful). Lower Q devices like ceramic resonators can be pulled a percent or so.
Thanks all... If it is possible to vary the frequency at least 0.5% by external capacitor or inductor.... How to calculate the value of those passive components for a particular frequency ,say for 0.5% increment of 28Mhz...
